[OpenLayers-Users] this.callbacks is undefined error
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Fri Mar 20 17:12:40 EDT 2009
Hi Bill,
this was because the proxy wasn't overriding the OGC mimetype to text/xml.
This is fixed now see:
http://trac.openlayers.org/changeset/9109
http://trac.openlayers.org/changeset/9110
Best regards,
Bart
Bill Thoen wrote:
> bartvde at osgis.nl wrote:
>> Hi,
>> first of all, please don't cross-post to dev and users if it is not
>> necessary.
>> Maybe you can check out the following for pointers:
>> http://dev.openlayers.org/sandbox/bartvde/wmsgetfeatureinfo/openlayers/lib/OpenLayers/Control/FeatureInfo.js
> I think this has a bug in it that brings down IE7.
> In the returnResponse() function of FeatureInfo.js I had to check for
> IE7 returning an empty string object in response.responceXML, and set
> it explicitly to null. Because if I didn't do that IE7 dies horribly
> when the code gets into the read() function in WMSGetFeatureInfo.js at
> line 74-75.
> Under the same conditions FireFox sets the response.responseXML to
> null and has no problems.
> - Bill Thoen
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
