[OpenLayers-Users] How to Set Up Layer Visibility by Scale
Bill Thoen
bthoen at gisnet.com
Fri Mar 20 19:05:19 EDT 2009
Thanks... I never would have guessed that. Is the sense of "max" and
"min" backwards as well? In other words, does maxscale apply to the
largest denominator or the largest scale (1/denominator)? To put it more
explicitly, if I set maxscale to 100000 does that mean that the layer is
visible between 1:1 and 1:100,000 or that it is visible only at scales
smaller than 1:100,000?
Bart van den Eijnden (OSGIS) wrote:
> Hi,
> minScale and maxScale should be denominators, so use 100000 and not
> 0.00001.
> Best regards,
> Bart
> Bill Thoen wrote:
>> I'm trying to get a WMS layer to appear only within a specific scale
>> range , and I not having any luck setting minscale and maxscale
>> properties when I load the layer onto the map. For example, I want
>> one layer land parcels to show from 1:1 up to 1:100,000 scale, so I
>> set minscale to 0.00001, expecting that once I zoom out to say,
>> 1:120,000, the land parcel layer should have its visibility property
>> set to false and the layer should be invisible. But it continues to
>> stay visible.
>> Can somebody tell me what I'm doing wrong? (I'm using OpenLayers 2.7,
>> in case that matters.)
>> - Bill Thoen
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
