[OpenLayers-Users] How to Set Up Layer Visibility by Scale
Bart van den Eijnden (OSGIS)
bartvde at osgis.nl
Sat Mar 21 06:55:57 EDT 2009
Indeed, minScale > maxScale in OL.
See:
http://trac.openlayers.org/wiki/SettingZoomLevels
Best regards,
Bart
Bill Thoen wrote:
> Thanks... I never would have guessed that. Is the sense of "max" and
> "min" backwards as well? In other words, does maxscale apply to the
> largest denominator or the largest scale (1/denominator)? To put it more
> explicitly, if I set maxscale to 100000 does that mean that the layer is
> visible between 1:1 and 1:100,000 or that it is visible only at scales
> smaller than 1:100,000?
> Bart van den Eijnden (OSGIS) wrote:
>> Hi,
>> minScale and maxScale should be denominators, so use 100000 and not
>> 0.00001.
>> Best regards,
>> Bart
>> Bill Thoen wrote:
>>> I'm trying to get a WMS layer to appear only within a specific scale
>>> range , and I not having any luck setting minscale and maxscale
>>> properties when I load the layer onto the map. For example, I want
>>> one layer land parcels to show from 1:1 up to 1:100,000 scale, so I
>>> set minscale to 0.00001, expecting that once I zoom out to say,
>>> 1:120,000, the land parcel layer should have its visibility property
>>> set to false and the layer should be invisible. But it continues to
>>> stay visible.
>>> Can somebody tell me what I'm doing wrong? (I'm using OpenLayers 2.7,
>>> in case that matters.)
>>> - Bill Thoen
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
OSGIS, Open Source GIS
bartvde at osgis.nl
http://www.osgis.nl
