[OpenLayers-Users] Classic GIS Info tool
Bill Thoen
bthoen at gisnet.com
Mon Mar 23 15:56:55 EDT 2009
I just got this going for a project I'm working on. You'll need modules
WMSGetFeatrueInfo.js and FeatureInfo.js which are not in the 2.7 OL
release, but you can get them from Bart's sandbox at:
http://dev.openlayers.org/sandbox/bartvde/wmsgetfeatureinfo/openlayers/lib/OpenLayers/Control/FeatureInfo.js
And here's a working example:
http://dev.openlayers.org/sandbox/bartvde/wmsgetfeatureinfo/openlayers/examples/featureinfo-control.html
You can see my demo scrapplication at
http://206.168.217.244/gallery/InfoTool.html and grab anything you want
to from that page. You have to set your browser to allow popup windows
for this one. Just click on the blue question mark button and then click
anywhere in the map over some visible layers. This should display a
small popup window in the traditional spot for the info window listing
all the layer info. It works in FireFox, but I don't know about IE.
Sometimes it doesn't seem to "take" on the first click.
The version I made opens up a separate window and lists all the
attributes you specify of all the WMS layers found under where you
click. I'm using MapServer to produce the WMS layers and for those you
want to be queryable, you've got to add some attributes in the mapfile.
Specifically in the WEB object, you need at least the last two lines of
metadata seen here (with your own content of course):
WEB
IMAGEPATH "/var/www/html/tmp/"
IMAGEURL "/tmp/"
METADATA
"wms_title" "VFM Data Layers"
"wms_onlineresource"
"http://***.***.***.***/cgi-bin/mapserv?map=/var/www/html/vfm/ms.map&"
"wms_srs" "epsg:900913 epsg:4326"
END
END
and for each layer you need at least the gml_include_items metadata and
the parameters DUMP TRUE and TEMPLATE (anything, but it doesn't have to
be a real template.) Looks like this:
LAYER
NAME "counties"
METADATA
"wms_title" "County Boundaries"
"gml_include_items" "NAME,STATE,COUNTY"
END
TYPE POLYGON
STATUS ON
DATA ../maps/data/County_tiger_2007_region
DUMP TRUE
TEMPLATE counties
You can also use "gml_include_items" "all" if you want all layer
attributes displayed.
Then in OpenLayers for each layer you want to be queryable, you need to
add the queryable:true parameter to the options object when you load
each WMS layer.
Since this uses AJAX , you may also need to set up a proxy script.
Anyway, if you do all that, you can then use this tool just like
MapInfo's Info tool. It's pretty fast too, and it can be made to respond
to a hover event if you like.
- Bill Thoen
jegou at univ-tlse2.fr wrote:
> Hello all,
> I'm using OpenLayers to build a geodata exploring map : several layers
> of polygons and points, with attributes data.
> To show those attributes to the visitor, i'd like to offer an Info
> tool, the classic "I" icon tool on our desktop GIS.
> I've tested the SelectFeature control, but it's only returning one
> feature at a time.
> I've seen the GetFeatureInfo control, but it's reserved to WFS
> datasources (i may be wrong), and i'm using a KML source (generated
> from PostGIS tables).
> I've also seen the GetFeature control from the trunk version docs :
> http://dev.openlayers.org/docs/files/OpenLayers/Control/GetFeature-js.html
> But i'm lost at testing it. Anyone has an example of it's use ?
> Another solution could be generating the on click features list by
> postgis, but it seems slow and counter-intuitive (the features are
> already client side).
> Thanks for any help,
> Laurent Jégou
> Dept. of Geography / Univ. Toulouse-2
> This message was sent using IMP, the Internet Messaging Program.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
