[OpenLayers-Users] Configure ProxyHost and KML files
Alexandre Dube
adube at mapgears.com
Thu Mar 26 08:31:11 EDT 2009
OpenLayers.Format.KMZ doesn't exist. You should try KML instead and
have &format=application/vnd.google-earth.kml+XML in your url instead.
I never tried it thought, but that's what I would try.
By the way, KMZ is a zipped version of a KML. You could replace a
file.kmz to file.zip then unzip it and you would have your uncompressed
KML. OpenLayers currently can't read KMZ files.
Regards,
Alexandre
Asle Benoni wrote:
> Yes, I have read that and configured proxy.cgi with the domains of the
> server.
> Now the layer I get from GeoServer is KMZ and not KML (don´t know why)
> so I put the code like this in my html.
> OpenLayers.ProxyHost = "/cgi-bin/proxy.cgi?url=";
> map.addLayer(new OpenLayers.Layer.GML("KML",
> "http://naturkart.no:8080/geoserver/wms/kml?layers=kulturminner_ns:gravminne&format=application/vnd.google-earth.kmz+XML&",
> format: OpenLayers.Format.KMZ,
> formatOptions: {
> extractStyles: true,
> extractAttributes: true
> I see now in FireBug that a http request is done to the kmz file but I
> do not see the layer in the map.
> /asle
Alexandre Dubé
Mapgears
www.mapgears.com
