[OpenLayers-Users] Get point on line?
paweluz
paweluz at o2.pl
Sat May 2 10:03:15 EDT 2009
Hi!
You can use this:
select astext(ST_LINE_SUBSTRING(
ST_LineMerge(the_geom),
0, 0.5)) from table
(the_geom is the line geometry) This returns the line geometry equals half
of the the_geom. If you have line geometry it returns half of it. Then you
can get the last point of that geometry I guess.
This:
ST_line_locate_point(st_linemerge(the_geom),GeometryFromText('POINT(0
4)',900913)))
This returns the value from 0 to 1 - how far is the point from the begining
of the geometry
I know this is not answer for you question fut you may look for similar
function :) I have been using those and it works great :)
Regards
Paul
View this message in context: http://n2.nabble.com/Get-point-on-line--tp2739966p2767539.html
