[OpenLayers-Users] layer event transparency
protos kildimo at gmail.com
Fri May 8 07:04:46 EDT 2009
I have a map with a transparent vector overlay over it, which has some
features.
I want the features to pickup click events and apart from that I want the
overlay
to allow all other events to go through the vector layer and get picked up
by the
layers below (map / markers etc)
The vector overlay z-index is higher than all other layers.
There are no events registered on the vector layer.
The features use the selectFeature to pick up events on them. (works fine)
I've set vectorLayer.event.fallthrough  to true
I've set vectorLayer.style.pointerEvents to 'none'
I can't get it to work though and the worst thing is that it's behaving very
strangely.
Some of the lower layers will pick up click events, some don't. dragging the
map
works. Events on all the map controls work.
Basically the map and one other layer seem to pick up all events.
2 other layers don't pick up any events.
If I remove the vector layer everything works fine so it definitely seems
to be the culprit
Can anyone see what the issue could be with this ?
Is there problems / bugs with vector layer events  - it seems to be very
inconsistent.
Any help appreciated.
Cheers.
View this message in context: http://n2.nabble.com/layer-event-transparency-tp2844713p2844713.html
