[OpenLayers-Users] IE7 popup problem with 2.8 rc2
Christopher Schmidt
crschmidt at metacarta.com
Fri May 8 10:56:38 EDT 2009
On Fri, May 08, 2009 at 02:53:19PM +0200, Frank Broniewski wrote:
> Ok you can see a minimal example here:
> http://www.gis-hosting.lu/ietestcase/ol28.html for the 2.8 rc2 Openlayers
> release I downloaded yesterday
> http://www.gis-hosting.lu/ietestcase/ol27.html for the stable release
> It is just an openstreetmap baselayer and a kml overlay. No stylesheets or
> other javascript. Both files share the same data I just adopted the link to
> the openlayers library. The server is sometimes somewhat slow though at times
I have concerned that this problem was introduced by the previously
mentioned change, and have reopened:
http://trac.openlayers.org/ticket/1906
As a blocker for 2.8.
-- Chris
> On Friday 08 May 2009 13:44:00 Christopher Schmidt wrote:
> > On Fri, May 08, 2009 at 11:29:43AM +0200, Frank Broniewski wrote:
> > > Hi list,
> > > I recently tested my maps with the new OL 2.8 rc2 version in order to
> > > make the multiple selectcontrol work. I use framed popups in my maps to
> > > display the data. However I noticed in IE7 that the popup size is not
> > > adapted to the content size, however it is when using OL 2.7.
> > > System is Win Xp64, 32bit Browser version.
> > > I tried to find the css differences, but there aren't any apparent
> > > changes that might cause this behavior, well at least I couldn't find
> > > any. If necessary I can provide a test example.
> > Please do, as minimal as possible.
> > The only change that seems relevant is
> > http://trac.openlayers.org/changeset/8906, and I can't imagine hwy that
> > would be an issue. However, I don't have IE handy to test atm, and I
> > want to fix any and all regressions in another RC.
> > > So I am just reporting this issue. Maybe someone else more skilled in JS
> > > and CSS is able to find out what's going on.
> > > I create my popups as following:
> > > var content = '<div style="width:350;height:250;overflow:auto;"> <h4>' +
> > > feature.attributes.name+'</h4> <p class="popupcode">' +
> > > feature.attributes.description + '</p> </div>';
> > > popup = new OpenLayers.Popup.FramedCloud("ptInfoPopup",
> > > feature.geometry.getBounds().getCenterLonLat(),
> > > null,
> > > content,
> > > null, true, function (evt) {
> > > selectControl.unselect(selectedFeature);
> > > popup.minSize = new OpenLayers.Size(100,150);
> > > popup.maxSize = new OpenLayers.Size(400,300);
> > > Frank Broniewski
> > > Metrico s.àr.l. ( http://www.metrico.lu )
> > > 36, rue des Romains
> > > L-5433 Niederdonven
> > > Luxembourg
> > > Fon: +352 26 74 94 28
> > > Fax: +352 26 74 94 99
> > > _______________________________________________
> > > Users mailing list
> > > Users at openlayers.org
> > > http://openlayers.org/mailman/listinfo/users
> Frank Broniewski
> 36, rue des Romains
> L-5433 Niederdonven
> Luxembourg
> Users mailing list
Christopher Schmidt
MetaCarta
