[OpenLayers-Users] Problem with multiple SelectFeature controls
Christopher Schmidt
crschmidt at metacarta.com
Fri May 8 14:58:40 EDT 2009
On Fri, May 08, 2009 at 10:29:47AM -0700, Coiler wrote:
> Andreas Hocevar-2 wrote:
> > Anexample is online at
> > http://dev.openlayers.org/sandbox/ahocevar/singleroot/openlayers/examples/select-feature-multilayer.html
> Is it able to display the marker layer over the vector layer. In this
> example it's seem not.
Right. The suggestion was "Don't use markers." Use all vector layers.
-- Chris
> As soon as I use OpenLayers.Control.SelectFeature, the vector layer is
> display as the top layer, and all my markers are behind polygon...
> I checked both z-index and they are always ok.
> If somebody has already found a solution ;)
> Thanks.
> View this message in context: http://n2.nabble.com/Problem-with-multiple-SelectFeature-controls-tp2156949p2846585.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
