[OpenLayers-Users] Get point on line?
shane_china
xiaying4415139 at 163.com
Sun May 10 02:55:29 EDT 2009
Bill Thoen, Thank you very much. With the help of the wiki page you give, I
success finish the function. The following is my code
function getPointOnLineByDistance(p1, p2, distance) {
var ppp1 = new Point(p1.x, p1.y);
var ppp2 = new Point(p2.x, p2.y);
var bearing = ppp1.geoBearingTo(ppp2);
var ppp3 = ppp1.geoWaypoint(distance, bearing);
return new OpenLayers.Geometry.Point(ppp3.x, ppp3.y);
Many points tested, this function works well. But I don't understand the
bearing. What is the bearing meaning? In the wiki page, it describes bearing
is the angle that p1 to p2 along a great circle route. So can a bearing
determine a great circle route? If it can't, how does this
function(geoWaypoint) work? On earth, there are many points to p1 have the
same distance.
Bill Thoen wrote:
> I put an article about great circle algorithms in the wiki some time ago
> that might help you. The links to the demos are down right now (that
> server needs a power supply I think) but the algorithms and formulas are
> shown on the wiki page at
> http://trac.openlayers.org/wiki/GreatCircleAlgorithms. Hopefully that
> will give you enough help to complete your task.
> Unfortunately, I'm swamped with my own OpenLayers problems right now, so
> I don't have any free time to help you much more than that. JavaScript
> and OpenLayers is so much fun that it's all too easy to program yourself
> into places you have no business being.
> But if you got the answers to all your problems immediately, your heart
> wouldn't become purified by the long quest.
> Good luck!
> - Bill Thoen
> shane_china wrote:
>> Hi, Bill Thoen, I go to the website and find the formulary I want. As
>> following:
>> Point(s) known distance from a great circle
>> Let points A and B define a great circle route and D be a third point.
>> Find
>> the points on the great circle through A and B that lie a distance d from
>> D,
>> if they exist.
>> A = crs_AD - crs_AB
>> ( crs_AB and crs_AD are the initial GC bearings from A to B and D,
>> respectively. Compute using Course between points)
>> b = dist_AD
>> (dist_AD is the distance from A to D. Compute using Distance between
>> points)
>> r=(cos(b)^2+sin(b)^2*cos(A)^2)^(1/2)
>> (acos(r) is the XTD)
>> p=atan2(sin(b)*cos(A),cos(b))
>> (p is the ATD)
>> IF (cos(d)^2 > r^2) THEN
>> No points exist
>> ELSE
>> Two points exist
>> dp = p +- acos(cos(d)/r)
>> ENDIF
>> dp are the distances of the desired points from A along AB. Their
>> lat/lons
>> can be computed using Lat/lon given radial and distance
>> But I want to know, Is there any such fomulary in OpenLayers to help me
>> simplify the algorithm? For example, I know
>> "OpenLayers.Util.distVencenty",
>> this method can calculate the distance between two points. Does
>> openlayers
>> also have such functions can help me? Thank you.
>> My math is not so good. Write the algorithm in js all by myself is so
>> difficult for me.
>> Bill Thoen wrote:
>>> Yes, it's a little different for the spherical (Lon/Lat) case. For those
>>> formulas, check out Ed Williams' Aviation Formulary website at
>>> http://williams.best.vwh.net/avform.htm. What you're looking for is
>>> determining waypoint locations, i think.
>>> - Bill Thoen
>>> shane_china wrote:
>>>> Bill Thoen wrote:
>>>>> shane_china wrote:
>>>>>> In openlayers,
>>>>>> I have a straight line with two endpoints. How could I get a point on
>>>>>> the
>>>>>> line with given distance to one endpoint? Thank you.
>>>>> You can find a point anywhere on a line by using a ratio calculation.
>>>>> Start with the distance to your point divided by the total distance of
>>>>> your line, then your new X coordinate = the difference between the X
>>>>> coordinates of the endpoints times the ratio (plus the X coordinate of
>>>>> the starting line endpoint. For example, if your endpoints are at
>>>>> coordinates (X0, Y0) and (X1,Y1) then the Cartesian distance is
>>>>> D = sqrt((X1-X0)*(X1-X0) + (Y1-Y0)*(Y1-Y0))
>>>>> Then if the ratio between this and the distance to your point is d,
>>>>> your
>>>>> new point's coordinates will be:
>>>>> X= X0+(X1-X0)*d/D
>>>>> Y=Y0+(Y1-Y0)*d/D
>>>> So thank you for your answer. Your advise is in X-Y coodinates. Does
>>>> this
>>>> method also apply to lon lat coodinates? Our earth is a ball, so is it
>>>> different?
>>>> I haven't demonstrate it yet.
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/Get-point-on-line--tp2739966p2853044.html
