[OpenLayers-Users] Problem alternating google bases with my own
wms bases
Alessio Di Lorenzo
alessio.dilorenzo at gmail.com
Mon May 11 11:52:11 EDT 2009
Sorry... but I have to UP! :)
Does exist a way to sync the zoom levels of Google base layers and WMS base
layers without removing numZoomLevels and maxZoomLevel?
Alessio Di Lorenzo wrote:
> Hi List,
> I have a map that uses Google layers as default base layers and I defined
> some options to avoid zooming too close or too far on the map
> options = {
> controls:[],
> maxExtent: bounds,
> restrictedExtent: restrBounds,
> maxResolution: "156543.0339",
> numZoomLevels:9,
> minZoomLevel:6,
> maxZoomLevel:15,
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units:"meters"
> I need to make available another base layer from my wms (cached with
> TileCache) and/or with an empty layer.
> I noticed that when I use my wms or the empty map as base layer I can't
> zoom in my overlays at the same level that I can reach with one of the
> Google base and the same overlay... the zooming level appears "locked".
> This problem disappear if I comment the numZoomLevels and maxZoomLevels
> parameter... but I need them.
> Is there a way to fix this?
> thx in advance, alessio
View this message in context: http://n2.nabble.com/Problem-alternating-google-bases-with-my-own-wms-bases-tp2284792p2863770.html
