[OpenLayers-Users] How can I display a map with a position
changing marker.
Kris Geusebroek
kgeusebroek at xebia.com
Wed May 13 02:09:58 EDT 2009
In my case it is stored in WGS84 in separate columns.
To help geoserver a bit I created an extra column with a SDO_GEOMETRY
(using Oracle Spatial db) with EPSG:4326 projection and an extra column
with Dutch RD projection (filled with a trigger) because the rest of
the map is in Dutch RD projection and this way no reprojection needs to
take place.
Cheers Kris
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of sasi
Sent: Wednesday, May 13, 2009 3:48 AM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] How can I display a map with a position
changing marker.
There is another thing I want to know.
Which format is the Lon&Lat information stored in the mysql database? Is
this a standard?
Kris Geusebroek wrote:
> Hi,
> Yes that's the whole point.
> The lon, lan will be in your db, you configure your datastore and
layer
> in geoserver
> In your openlayers based client you configure your layers as a vector
> layer with bbox strategy and wfs protocol
> Where the wfs protocol must be configured to connect to the right
layer
> and geoserver instance.
> Something like this:
> var wfsLayerOptions = {
> url: GEOSERVER_WFS_URL,//something like
> http://localhost:8080/geoserver/wfs
> geometryName: "GEOMETRY",
> featureNS: FEATURENAMESPACE,//something like
> http://www.blah.org/topp
> version: "1.0.0"
> var layerOptions = {
> filter: filter,
> projection: RDPROJECTION
> wfsLayer = new OpenLayers.Layer.Vector("wfsLayerName",
> OpenLayers.Util.extend({
> styleMap: styles[0],
> strategies: [
> new OpenLayers.Strategy.BBOX(),
> new OpenLayers.Strategy.Cluster({
> threshold: 2,
> distance: 30
> protocol: new OpenLayers.Protocol.WFS(
> featureType:
> 'LAYER_NAME_IN_GEOSERVER'
> }, wfsLayerOptions)
> }, layerOptions)
> Cheers Kris
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context:
http://n2.nabble.com/How-can-I-display-a-map-with-a-position-changing-ma
rker.-tp2861920p2878521.html
Users mailing list
