[OpenLayers-Users] KML NetworkLink and auto-refresh
ChiefDan ChiefDan at gmail.com
Wed May 13 16:40:14 EDT 2009
Andrew,
I honestly haven't done extensive testing to notice if it flickers or not. I
did set the timer to 1000ms to test that it would go grab the file and it
didn't seem to flicker, but I am not 100% confident I have it all working
smoothly.
If you don't mind, keep posting to this thread with anything you discover
and I'll do the same.
Dan
Andrew Smith wrote:
> Thanks Dan, I'll have to give this a try.
> I notice that your timer is going off every 10 minutes...how much data are
> you loading from the KML file?  Is there much in the way of a noticeable
> flicker when you reload the layer (i.e. does all of the data completely
> disappear for a few seconds while the KML file is parsed and reloaded)?
> I'd be looking to reload a layer containing between 20-100 text objects
> every 5 seconds or so and I'm not sure what the performance will be like
> under those conditions.
> Cheers,
> Andrew
> On Wed, May 13, 2009 at 1:35 AM, ChiefDan <ChiefDan at gmail.com> wrote:
>> Andrew,
>> Not sure if you found a solution, if not, this is what I've done.
>> In the map init function, set a timer:
>> window.setInterval(raingaugeRefreshData, 600000, rainGauges);
>> Then in the timer service function:
>> function raingaugeRefreshData(layer)
>>  layer.loaded = false;
>>  layer.setVisibility(true);
>> By setting loaded to false then calling setVisibility(), openlayers goes
>> and
>> grabs the kml file again.
>> Hope this helps.
>> Dan
>> View this message in context:
>> http://n2.nabble.com/KML-NetworkLink-and-auto-refresh-tp2531433p2870627.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
> Users mailing list
View this message in context: http://n2.nabble.com/KML-NetworkLink-and-auto-refresh-tp2531433p2886417.html
