[OpenLayers-Users] Using AutoCAD files (DWG, DXF and similar)
Lehtonen, Mika
mika at digikartta.net
Thu May 14 15:25:48 EDT 2009
Hi Pawel,
depends on how complex your cad geometries/files are. You could also try
OpenJUMP (www.openjump.org) with separately downloaded DXF-import
plugin. With that package, you can convert your dxfs' into some other
format and use them directly in OL or better, serve them throug some map
server. If your files are complex, you'd better stick to some raster
format. Main question might be; do you need vectors or just an image of
them?
- mika -
Paw3l kirjoitti:
> Hi,
> I'm wondering if it is possible to use Autocad format files directly in the
> OpenLayers. For now I am using a converted to PNG version of my DXF file:
> new OpenLayers.Layer.Image('Sem',
> 'http://localhost:8080/swanny/images/SektorVI.png',
> new OpenLayers.Bounds(-180, -88.759, 180, 88.759),
> new OpenLayers.Size(1024, 768),
> options
> but I would like to use a DXF file instead of PNG. I could not find any
> pointers anywhere.
> Regards,
> Pawel
