[OpenLayers-Users] help !
Alexandre Dube
adube at mapgears.com
Mon May 18 14:53:59 EDT 2009
Hi Hugo,
I understand more what you want to do. Please reply to the list so
that users and developers can help you too.
I see that you use GeoServer. I'm pretty sure that you can use
filters/cql/other (I never used GeoServer but heard about it) to have a
specific feature rendered differently. You should ask the GeoServer
list for that.
You could also have a Vector layer instead of a WMS layer for your
roads and define a different style for your results. See
http://trac.openlayers.org/wiki/Styles
Best regards,
Alexandre
Hugo Teixeira wrote:
> hi,
> i'm using a polyline, this is what i'm doin'g
> :http://84.91.20.142:82/webvias/index.php
> try search : rua vale verde
> i found the street and i goes to it, but now i need to highlight the
> street to the user ...
> regards,
> hugo
> 2009/5/15 Alexandre Dube <adube at mapgears.com <mailto:adube at mapgears.com>>
> Hi Hugo,
> What type of layer are you using ? The easiest way to achieve
> this is to use a vector layer with a selectFeature control
> hover:true and highlightOnly:true. See the example (1). You need
> OpenLayers 2.8 or trunk for the highlightOnly property
> Regards,
> Alexandre
> (1) http://openlayers.org/dev/examples/highlight-feature.html
> how can i hilight one line in openlayers ???
> Users mailing list
> Users at openlayers.org <mailto:Users at openlayers.org>
> http://openlayers.org/mailman/listinfo/users
> Alexandre Dubé
> Mapgears
> www.mapgears.com <http://www.mapgears.com>
> Pestinha
Alexandre Dubé
Mapgears
www.mapgears.com
