[OpenLayers-Users] [OpenLayers-Dev] Getting Help Faster: Minimize Your Code
Eric Lemoine eric.lemoine at camptocamp.com
Mon May 18 18:02:09 EDT 2009
thanks a lot for putting this email together Chris, shall we
copy&paste it somewhere for future reference?
Eric
On Friday, May 15, 2009, Christopher Schmidt <crschmidt at metacarta.com> wrote:
> Hi,
> (Cross-posted to dev and users: please send all replies to the users list.)
> Many times, users have come to me, or asked questions in IRC, related to
> getting help with a particular behavior. Whether that behavior is a bug
> or user error, there is one thing that you can do to make it more
> likely that a developer will be able to quickly help you with your
> problem. (In some cases, this is the difference between getting help at
> all, and simply not receiving any.) I have never seen any situation
> where this rule does not apply, and so I want to share it publicly with
> the users and dev communities so that we can all learn from it, and
> learn how to help each other more quickly and easily.
> (Throughout this post, I use the terms 'developers' and 'users'. By
> these terms, I mean "persons who have knowledge of the code inside of
> the OpenLayers library" and "persons who have knowledge of using the
> OpenLayers library, but not what is inside the library itself.")
> Minimizing Test Cases
> In order for developers to help fix a problem, they first have to
> understand it. In order to do that, they need to understand everything
> thati s going on in a situation where the problem is reproducible.
> Oftentimes, the particular behavior is only existing in a certain type
> of situation, or in a limited case that is not exploited by the commonly
> used code. (In addition, some problems are the result of user error in
> some way.)
> In order to help developers help you, the best thing to do is to
> minimize the error to the *smallest amount of code that can cause it to
> happen*. Additionally, when attempting to reproduce, any developer will
> need to set up the code so that it is possible to run in the developer's
> test environment. This means that it is ideal to remove external
> references to other Javascript files, and external files at all, where
> possible. (Clearly, this is not always possible: WFS server bugs can't
> typically be demonstrated inside of a single page, for example -- but
> you should minimize external dependancies as much as possible.)
> Once you've done this, you should remove *all non-neccesary lines of
> code* from your example. Does the problem require the ScaleBar control
> in order to manifest itself? If not, toss it. Does it need multiple
> layers? If not, toss them. In short, any line of code that is not
> directly related to reproducing the problem should be removed, as each
> line will need to be read by the developer -- and in the case of
> multiple developers working on a problem, read by *each* developer -- in
> order to determine whether the problem is related to that.
> This minimization step should include removing any unneccesary
> Javascript, unneccesary CSS files, unneccesary HTML, etc. until the
> resulting code is as small as possible.
> Many times, in doing this, you will come across a particular
> minimization step that causes the problem to go away. This is a good
> sign, because it means you have narrowed the problem down to that
> particular aspect of code. Put it back, and keep minimizing.
> Additionally, many times in doing this, you find a particular construct
> in your code that can help you understand how to work around the
> problem.
> If not, then continue onto the next section.
> OpenLayers Library References
> There are multiple hosted versions of the OpenLayers library.
>   http://openlayers.org/api/OpenLayers.js
> This will always represent the most recent released 'stable' version of
> the OpenLayers API.
>  http://openlayers.org/dev/OpenLayers.js
> This is always a 10-minute delayed build of OpenLayers trunk.
> To simplify allowing developers to set up the code on their own testing
> environments, it is often beneficial to point directly to one of these
> library URLs. In addition, this also ensures that the problem is not
> something specific to your build of OpenLayers.
> Publishing your Problem
> Once you have minimized your test case, you need to publish it. In
> general, it is easiest if you publish an HTML page on a web accessible
> URL. Even if your project is not yet public, you can likely put a page
> up on another server which demonstrates the problem. Doing this is much
> more likely to have a developer actually follow the link and explore
> your problem. This is *especially* true for things like WFS which
> require a proxy to work correctly:  Downloading the page, setting up a
> proxy, and testing locally is a lot of work for a developer simply to
> confirm that a problem exists.
> If you do not have *any* place to publish webpages, you can attempt to
> paste your code to a public site like 'nopaste.com'. However, be aware
> that doing so means that a developer has to perform more steps to
> reproduce your problem -- and every step is one that makes the problem
> less likely to be solved quickly and easily.
> Communicating about your Problem
> The best way to communicate your problem is to send an email to the
> users list demonstrating the problem. Oftentimes other users will be
> able to point out a particular flaw in your code that is causing the
> error, or explain that the behavior is a known lack of functionality in
> OpenLayers.
> *Be clear on steps for reproduction*. Users who don't know what they're
> supposed to do to cause the bug will not be able to see it, and if they
> can't see it, they can't help you.
> If you have determined the particular change in the OpenLayers source
> code which is required to change the behavior, then it is more likely
> that the Developers list is the best place to go. Any discussion which
> involves code from OpenLayers itself is probably better suited for the
> dev list.
> Finally,
> By following the steps:
>  * Simplify/Minimize
>  * Publish
>  * Communicate
> (If you'd like, you can toss a "???, Profit!" at the end of this.)
> You can ensure that it is as easy as possible for a developer to
> determine whether the problem you're having is with the library. You
> also make it easier for develpoers and users to find potential problems
> in your usage of the library and suggest solutions. Finally, you may
> find in the process that you find the bug yourself, thus saving yourself
> and everyone else time in trying to debug.
> The end result is a more workable system for everyone. The easier it is
> to understand the problem you're having, the faster, and more easily,
> you will be able to get help.
> Best Regards,
> Christopher Schmidt
> MetaCarta
> Dev mailing list
> Dev at openlayers.org
> http://openlayers.org/mailman/listinfo/dev
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
