[OpenLayers-Users] rootContainer and selectFeature on many
layers
Kris Geusebroek
kgeusebroek at xebia.com
Tue May 19 16:26:10 EDT 2009
I'm using the selectfeature with multiple vectorlayers with wfs protocol
successfully.
Here's my code:
var hoverOptions = {
multiple: false, hover: true,
toggleKey: "ctrlKey", // ctrl key removes from selection
multipleKey: "shiftKey", // shift key adds to selection
overFeature: function(feature) {
if (this.hover &&
(OpenLayers.Util.indexOf(feature.layer.selectedFeatures, feature) ==
-1)) {
var position =
feature.geometry.getBounds().getCenterLonLat();
if (this.handlers &&
this.handlers.feature && this.handlers.feature.evt &&
this.handlers.feature.evt.xy) {
position =
this.handlers.feature.evt.xy;
showDescription(feature, position, true);
outFeature: function(feature) {
if (this.hover) {
hideDescription(feature, true);
var descOnHover = new
OpenLayers.Control.SelectFeature([wfsPunten,wfsLijnen,wfsGebieden],
hoverOptions);
map.addControl(descOnHover);
the showDescription function creates a popup to show some attributes of
the feature to the user
Hope this is of use for u (btw I'm using latests version from trunk)
Cheers Kris
-----Original Message-----
From: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org]
On Behalf Of Simo D
Sent: Tuesday, May 19, 2009 4:46 PM
To: users at openlayers.org
Subject: Re: [OpenLayers-Users] rootContainer and selectFeature on many
layers
Hi, I have the same problem. I upgraded the SelectFeature and
RootContainer
from the trunk in order to have custom popups on multiple GML layers.
But
unfortunately this trick works only in Safari 4.
It's also interesting for me to find a solution to this issue.
Simone
Simone Gadenz wrote:
> Hello! After one message on the list couple of days ago I tried to use
the
> root container to enable the selectfeature on a set of defined GML
layers.
> Has anybody managed to use the rootContainer that is into the trunk?
> Currently I defined the selectfeature using the following code:
> var ctrl_rootlayer = new
> OpenLayers.Control.SelectFeature([a,b,c],function());
> map.addControl(ctrl_rootlayer);
> ctrl_rootlayer.activate();
> The root layer is empty in the produced container (according to
firebug).
> Cheers
> Simone
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context:
http://n2.nabble.com/Re%3A-Is-it-possible-to-get-openlayers-version-2.8-
-tp2886380p2939981.html
Users mailing list
