[OpenLayers-Users] [OpenLayers-Dev] Help: loadURL in IE failed
tanpopo
weitstern at yahoo.com
Wed May 20 06:59:42 EDT 2009
Hi Andre,
thanks, yes, i have checked, the option is deactivate, and
1) the error 'Unhandelt request return NOT Found.' comes up with the line
"OpenLayers.loadURL(url, null, this,parseGetCapabilities);"
2) and the error 'The object doesn't support the character or the
methode.' by the code:
"var request = OpenLayers.Request.GET({url: url,
callback: parseGetCapabilities});"
these errors happen not only on my computer, but also on the others in the company. while the company strongly controls the network(in and out), can it be the reason for example proxy etc.?
My work stops because of the problem, i will very appreciate your help.
Thank you very much!
beste regards,
tanpopo
--- André Mendonça <andremalms at hotmail.com> schrieb am Mi, 20.5.2009:
> Von: André Mendonça <andremalms at hotmail.com>
> Betreff: RE: [OpenLayers-Users] [OpenLayers-Dev] Help: loadURL in IE failed
> An: weitstern at yahoo.com
> Datum: Mittwoch, 20. Mai 2009, 1:36
> #yiv1457494256 .hmmessage P
> margin:0px;padding:0px;}
> #yiv1457494256 {
> font-size:10pt;font-family:Verdana;}
> Hi tanpopo
> on IE, which line is identified by the script as
> wrong?
> you have to deactivate the option: Disable script debugging
> (IE) on tools/internet options/advanced, have you done
> this?
> with the line known, copy it here, with all its
> dependencies and we try to understand the error.
> Andre
> > Date: Tue, 19 May 2009 17:11:30 +0000
> > From: weitstern at yahoo.com
> > Subject: Re: [OpenLayers-Users] [OpenLayers-Dev] Help:
> > To: users at openlayers.org; andremalms at hotmail.com
> > Hi Andre ,
> > thank you a lot! I have tried what you told, but it
> still errors.
> > if i use OpenLayers.loadURL, in IE it returns
> 'Unhandelt request return NOT Found.',
> > and if i use OpenLayers.Request.GET, in IE it returns
> methode.'
> > So if i want to use cross-browser ajax, which one and
> how i should use exactly? I have also tried the
> XMLHttpRequest, but no effect, it errors even in FF. Had i
> wrong with using?
> > best regards,
> > tanpopo
> > > Von: André Mendonça
> > > Betreff: Re: [OpenLayers-Users] [OpenLayers-Dev]
> > > An: users at openlayers.org
> > > Datum: Mittwoch, 20. Mai 2009, 0:56
> > > #yiv617337405 .hmmessage P
> > > #yiv617337405 {
> > > Hi,
> > > turn the error script messaging
> "on" in
> > > IE (somewhere at tools/internet options/
> advanced).
> > > Then when the error occurs it will inform you the
> exact
> > > line of the code that is causing the error.
> > > Usually, IE has javascript problems with spaces
> and
> > > commas.
> > > Andre
> > > > Date: Tue, 19 May 2009 16:48:53 +0000
> > > > Subject: [OpenLayers-Users] [OpenLayers-Dev]
> Help:
> > > > Hello all,
> > > > i develope one site mit OL, it runs good in
> FF, but
> > > stops in IE,
> > > > and maybe stops for:
> > > > it returns 'Request failed'.
> > > > So i tried to change, because the site
> should also run
> > > in IE, first :
> > > > url: url,
> > > > It succeed still only in FF, the IE said
> that the
> > > object doesn't support the charcter.
> > > > Dann i changed it again:
> > > > var client =new
> OpenLayers.Request.XMLHttpRequest();
> > > > client.open("GET", url);
> > > > client.send();
> > > > if(client.readyState == 4 &&
> client.status ==
> > > 200) {
> > > > // so far so good
> > > > alert('responseXML' +
> client.responseXML);
> > > > if(client.responseXML != null){
> > > > parseGetCapabilities(client.responseXML);
> > > > } else if (client.readyState == 4
> > > client.status != 200) {
> > > > // fetched the wrong page or network
> error...
> > > > alert('XMLHttpRequest errors. ');
> > > > This doesn't run both in FF and IE, in
> FF the
> > > readyState returned 4 and status was 404 and
> reponseXML was
> > > null, in IE the readyState = 1 and status was 404
> and
> > > reponseXML was null.
> > > > Could somebody kindly help me? Since i
> worked on this
> > > problem already several weeks, and still
> can't find a
> > > way.
> > > > Best regards,
> > > > Tanpopo
> > > > Users mailing list
> > > > Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
> > > Quer uma internet mais segura? Baixe
> > > agora o novo Internet Explorer 8. É grátis!
> > > -----Integrierter Anhang folgt-----
> > > _______________________________________________
> > > Users mailing list
> Conheça os novos produtos Windows Live. Clique aqui!
