[OpenLayers-Users] Are String objects limited to 4096
characters?
Stephen Woodbridge
woodbri at swoodbridge.com
Wed May 20 11:01:10 EDT 2009
Christopher Schmidt wrote:
> On Tue, May 19, 2009 at 02:58:53PM -0400, Stephen Woodbridge wrote:
>> Hi all,
>> I'm trying to parse some WKT out of an XML document in an OpenLayers
>> application and one of my WKT text nodes is getting truncated at 4096
>> character! The XML document is good, but when I extract the text from
>> the XML node it is getting truncated.
>> It seems to work in IE 6.0.2800 and Opera 9.64, but not FF 3.0.10.
>> So is looks like FF breaks the text into an array of strings where each
>> is 4096 characters or less. Can I pass this array to the WKT parser read
>> function? Or can I concat the items into a string?
> http://dev.openlayers.org/apidocs/files/OpenLayers/Format/XML-js.html#OpenLayers.Format.XML.getChildValue
> -- Chris
Thank you again. I took the day and tossed my old code, and wrote a new
reader that inherited from OpenLayers.Format.XML and it was pretty
straight forward. New code works great and it much cleaner than my old
hack. I'm not sure why I did not do this in the first place ... oh well!
Reading through OL code and the API, I see that concatChildValues() is
depreciated and it points to getChildValue() which appears to only get
the first child.
Is getChildValue() doing something tricky that I missed?
I also see getChildEl() and getNextEl() which might be used to loop
through the children to concat the results.
Regards,
-Steve
>> var parser = new OpenLayers.Format.WKT();
>> var edges = xmldoc.getElementsByTagNameNS('*', 'edge');
>> var wkt = edges[0].getElementsByTagNameNS('*', 'wkt');
>> var g = parser.read(wkt);
>> Any help or suggestions would be appreciated.
>> Thanks,
>> -Steve
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
