[OpenLayers-Users] Small shift between google and wms
Christopher Schmidt
crschmidt at metacarta.com
Fri May 22 11:17:50 EDT 2009
On Fri, May 22, 2009 at 08:07:03AM -0700, Simo D wrote:
> I'm using a trunk version of the 2.8 checked out about three days ago.
> Shall I checkout a newer version?
No, i think any potential fix would be included in that. Do you have a
URL that people can see this at?
> Christopher Schmidt-2 wrote:
> > On Fri, May 22, 2009 at 07:57:02AM -0700, Simo D wrote:
> >> Hi, I created an application which retireves a WMS layer from geoserver
> >> (chached in epsg:900913), the layers from google and a layer from virtual
> >> earth plus some georss(GML+GeoRSS format). The issue is that when I
> >> switch
> >> from wms to google, there is a small shift of the map, so the georss are
> >> displayed in a wrong place. This shift disappears when zooming and is not
> >> present with virtual earth.
> > Are you using OL 2.8? A fix was checked into RC2 to fix this, I believe.
> >> All the layers have the sphericalMercator set to true. Here follows a
> >> piece
> >> of my code:
> >> var options = {
> >> projection: new OpenLayers.Projection("EPSG:900913"),
> >> displayProjection: new OpenLayers.Projection("EPSG:900913"),
> >> units: "m",
> >> maxResolution: 156543.0339/4,
> >> maxExtent: new OpenLayers.Bounds(-20037508.34,
> >> -20037508.34,20037508.34,
> >> 20037508.34),
> >> restrictedExtent: new OpenLayers.Bounds(-20037508.34,
> >> -20037508.34,20037508.34, 20037508.34),
> >> numZoomLevels: 10,
> >> zoom: 1,
> >> controls: []
> >> var world = new
> >> OpenLayers.Layer.WMS("WFP-SDI",geoweb,{layers:'ithaca_world',"sphericalMercator":
> >> true,format: 'image/png'});
> >> var gmap = new OpenLayers.Layer.Google("Google
> >> Streets",{'sphericalMercator': true,minZoomLevel: 2});
> >> var gphy = new OpenLayers.Layer.Google("Google Physical",{type:
> >> G_PHYSICAL_MAP,"sphericalMercator": true,minZoomLevel: 2});
> >> var gsat = new OpenLayers.Layer.Google("Google Satellite",{type:
> >> G_SATELLITE_MAP, 'sphericalMercator': true,minZoomLevel: 2});
> >> var vaer = new OpenLayers.Layer.VirtualEarth( "VE",{ minZoomLevel: 2,
> >> maxZoomLevel: 12, 'type': VEMapStyle.Aerial,'sphericalMercator': true});
> >> Have you got any advice?
> >> Thanks a lot.
> >> Simone
> >> View this message in context:
> >> http://n2.nabble.com/Small-shift-between-google-and-wms-tp2957923p2957923.html
> >> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> >> _______________________________________________
> >> Users mailing list
> >> Users at openlayers.org
> >> http://openlayers.org/mailman/listinfo/users
> > Christopher Schmidt
> > MetaCarta
> > Users mailing list
> View this message in context: http://n2.nabble.com/Small-shift-between-google-and-wms-tp2957923p2957979.html
> Users mailing list
Christopher Schmidt
MetaCarta
