[OpenLayers-Users] [OpenLayers-Dev] My map will not zoom in
past 1: 1066
Robert Hicks
robhyx at gmail.com
Fri May 22 12:55:24 EDT 2009
Thanks Chris, I actually did try that and I get the same result.
On Fri, May 22, 2009 at 12:51 PM, Chris Claydon
<chris.claydon at autodesk.com>wrote:
> Are you setting the number of zoom levels on the map or on the google
> layer? In a recent discussion I was led to believe that OL will pick up
> settings from the base layer rather than the map…
> This may be a red herring, but it’s something to try.
> Chris.
> *From:* dev-bounces at openlayers.org [mailto:dev-bounces at openlayers.org] *On
> Behalf Of *Robert Hicks
> *Sent:* Friday, May 22, 2009 10:18 AM
> *To:* users at openlayers.org; dev at openlayers.org
> *Subject:* [OpenLayers-Dev] My map will not zoom in past 1: 1066
> No matter what I change in my options which are passed into the map
> constructor I cannot zoom in on my map past a scale of 1:1066.
> Here are my options:
> var options = {
> projection: new OpenLayers.Projection("EPSG:900913"),
> displayProjection: new OpenLayers.Projection("EPSG:4326"),
> units: "m",
> numZoomLevels: 27,
> maxExtent: new OpenLayers.Bounds(-20037508, -20037508,
> 20037508, 20037508.34)
> My base map:
> var google = new OpenLayers.Layer.Google(
> "Google Maps",
> 'sphericalMercator': true
> I have tried increasing numZoomLevels and adding minScale, minResolution.
> No effect so I have taken them out.
myspace http://www.myspace.com/diemtvdie
aim hyx1138
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090522/1e94ee40/attachment.html
