[OpenLayers-Users] Draw Polygons and Export Geometry
Robert Sanson
SansonR at asurequality.com
Sun May 24 17:04:37 EDT 2009
Hi Josh
I have a web site that reads in JSON to create a layer of crops. This layer can be modified. I then write out the geometry of the selected features. Here are the code snippets:
//declare the format
var geojson_format = new OpenLayers.Format.GeoJSON();
//add the layer
crops = new OpenLayers.Layer.Vector("Crop areas",
{isBaseLayer: false,
style: crop_style,
extractAttributes: true });
crops.addFeatures(geojson_format.read(cropsresponse.responseText));
map.addLayer(crops);
map.zoomToExtent(crops.getDataExtent());
//Select, Draw and Modify controls - these are specific to the layer
controls = {
select: new OpenLayers.Control.SelectFeature(crops, {callbacks: {'over':feature_info}}),
dpolygon: new OpenLayers.Control.DrawFeature(crops,OpenLayers.Handler.Polygon),
modify: new OpenLayers.Control.ModifyFeature(crops),
delf: new OpenLayers.Control.SelectFeature(crops, {onSelect: function(feature) {crops.destroyFeatures([feature])}})
//delf: new OpenLayers.Control.SelectFeature(crops, {onSelect: function(feature) {feature.geometry.destroy();crops.eraseFeatures([feature])}})
for(var key in controls) {
map.addControl(controls[key]);
//write out the geometry into a div
function feature_info(feature) {
var html = "<ul>";
OpenLayers.Util.getElement('crop').innerHTML = "<strong>ID:</strong>" + feature.attributes.prop0 + " <strong>Area:</strong>" + (Math.round(feature.geometry.getArea() / 100) / 100).toString() + " Ha";
var json = geojson_format.write(feature);
json = json.replace(/,/g, ', ');
document.getElementById('comments').innerHTML = json;
Hope that gives you some starters.
regards,
Robert S.
>>> "Josh S." <jstreufe at utk.edu> 23/05/2009 5:07 a.m. >>>
I need to export the geometries of multiple polygons a user draws, my plan is
to use json to export the geometries to another .js I'm using. Any
tips/help/code would be great.
-Josh
View this message in context: http://n2.nabble.com/Draw-Polygons-and-Export-Geometry-tp2958594p2958594.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090525/481b57b8/attachment.html
