[OpenLayers-Users] Overlay on Google
moony
k_karo at web.de
Tue May 26 04:49:16 EDT 2009
Hello,
I have two baselayers. When I use basemap as baselayer, I could add the
overlay, but with google as baselayer I got a error message "Paramenter
'src' contains unacceptable value". The services are delivered by arcgis
server 9.3.
I cannot see my mistake. What did I forget?
Below is my code. The services are only available within intranet.
Thanks!
var map;
var webproj = "EPSG:102113";
var webextent = new OpenLayers.Bounds(-20037508, -20037508, 20037508,
20037508.34);
var webunits= "m";
function init(){
var options = {
maxExtent : webextent,
projection: webproj,
units: webunits,
maxResolution: 156543.0339,
numZoomLevels: 9
map = new OpenLayers.Map( $('map') , options);
var gphy = new OpenLayers.Layer.Google(
"Google Physical",
{type: G_HYBRID_MAP, 'sphericalMercator': true}
map.addLayer(gphy);
var basemap = new OpenLayers.Layer.WMS( "Basemap",
"http://xen1ags:8399/arcgis/services/Monitor/Bevoelkerung_Bundesland_Web_Mercator/MapServer/WMSServer",
{layers: '0', format: 'image/png', transparent: 'true'},
{singleTile: true, isBaseLayer: true});
map.addLayer(basemap);
var wms = new OpenLayers.Layer.WMS( "WMS",
{layers: '1', srs: 'EPSG:102113', format: 'image/png',
transparent: 'true'}, {'reproject': false, 'opacity': 0.4, isBaseLayer:
false});
map.addLayer(wms);
map.setCenter(OpenLayers.Layer.SphericalMercator.forwardMercator(10.205188,51.457593),
6);
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.addControl(new OpenLayers.Control.MousePosition());
View this message in context: http://n2.nabble.com/Overlay-on-Google-tp2973539p2973539.html
