[OpenLayers-Users] ZoomToExtent works in Firefox, Safari and IE7,
but not in IE6
sendeman
martijnsendenspam at gmail.com
Tue May 26 04:51:44 EDT 2009
Hi All,
Does anybody have any ideas that might be of help for the problem I
described previously? Thanks a lot in advance for any help.
If I didn't explain the problem well enough, please let me know, so I can
clarify it.
Best regards,
Martijn Senden.
sendeman wrote:
> Hi all,
> I'm trying to make a 'fluid' layout, in which the viewport of the map
> changes with changes in the size of the browser window. I have some html
> and css worked out that do this without javascript in IE6. The only
> problem I have is that the initial zoom level doesn't work in IE 6. IE 6
> zooms in to the maximum level. Other browsers (IE7, FF, Safari, Chrome) do
> set the zoom level correctly.
> I set the zoom level as follows:
> map.zoomToExtent(new
> OpenLayers.Bounds(3.27392578125,50.69471783819287,7.294921875,53.67068019347264));
> What is it that makes IE 6 go wrong?
> Any help would be greatly appreciated!
> Below is the entire code of my test-site.
> Best regards,
> Martijn Senden.
> ____________________________
> __________</CODE>__________
> <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01//EN"
> "http://www.w3.org/TR/html4/strict.dtd">
> <html lang="NL">
> <head>
> <title>minOpenLayers.aspx</title>
> <script type="text/javascript" src="javascript/OpenLayers.js"></script>
> <!--[if lt IE 8]>
> src="http://ie7-js.googlecode.com/svn/version/2.0(beta3)/IE8.js"></script>
> <![endif]-->
> <script type="text/javascript">
> var map, layer;
> function init(){
> map = new OpenLayers.Map( 'map' );
> layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> "http://labs.metacarta.com/wms/vmap0", {layers: 'basic'} );
> map.addLayer(layer);
> </script>
> <style type="text/css">
> #map
> background-color: Red;
> position: absolute;
> width: 100%;
> height: 100%;
> #mapWrapper {
> position: absolute;
> background-color: Blue;
> top: 76px;
> bottom: 0px;
> left: 0px;
> right: 0px;
> </style>
> </head>
> <body onload="init()">
> <div id="mapWrapper"><div id="map" class="smallmap"></div></div>
> </body>
> </html>
View this message in context: http://n2.nabble.com/ZoomToExtent-works-in-Firefox%2C-Safari-and-IE7%2C-but-not-in-IE6-tp2969934p2973551.html
