[OpenLayers-Users] Control activate and deactivate events
Robert Sanson
SansonR at asurequality.com
Wed May 27 17:13:34 EDT 2009
Hi George
Here is how I specify the controls:
//Select, Draw and Modify controls - these are specific to the layer
controls = {
select: new OpenLayers.Control.SelectFeature(crops, {callbacks: {'over':feature_info}}),
dpolygon: new OpenLayers.Control.DrawFeature(crops,OpenLayers.Handler.Polygon),
modify: new OpenLayers.Control.ModifyFeature(crops),
delf: new OpenLayers.Control.SelectFeature(crops, {onSelect: function(feature) {crops.destroyFeatures([feature])}})
//delf: new OpenLayers.Control.SelectFeature(crops, {onSelect: function(feature) {feature.geometry.destroy();crops.eraseFeatures([feature])}})
for(var key in controls) {
map.addControl(controls[key]);
Then I have a function that responds to radio buttons in a div outside the map that sets the mode and activates or deactivates the controls:
function toggleControl(element) {
mode = element.value;
OpenLayers.Util.getElement('comments').innerHTML = "Mode:" + mode;
if ((mode == "select") || (mode == "modify")){
crop_style.strokeColor = "#0000ff";
else {
crop_style.strokeColor = "#ff0000";
for(key in controls) {
var control = controls[key];
if(element.value == key && element.checked) {
control.activate();
} else {
control.deactivate();
crops.onFeatureInsert = function(feature) {
feature.attributes.prop0 = 'new'; //This should be modified to get actual ID
alert("New crop area inserted");
Hope that helps.
Robert S
>>> Geo-rge <George at muammar.net> 28/05/2009 8:41 a.m. >>>
Dear List,
I am having trouble trying to capture events when the ModifyFeature control
is activated and deactivated.
I define my control as such:
modify = new
OpenLayers.Control.ModifyFeature(lyrPlanning,{'displayClass':
'olControlModifyFeature',
'mode': OpenLayers.Control.ModifyFeature.RESHAPE |
OpenLayers.Control.ModifyFeature.DRAG |
OpenLayers.Control.ModifyFeature.ROTATE});
I try to register the event like this:
modify.events.register('deactivate',modify,modify_deactivated);
this last line causes a syntax error!
I had already defined
function modify_deactivated() {alert('!');}"
I have that feeling that I am doing something so silly I will never get it.
Appreciate any help
George Mu'ammar
View this message in context: http://n2.nabble.com/Control-activate-and-deactivate-events-tp2983592p2983592.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
The contents of this email are confidential to AsureQuality. If you have received this communication in error please notify the sender immediately and delete the message and any attachments. The opinions expressed in this email are not necessarily those of AsureQuality. This message has been scanned for known viruses before delivery. AsureQuality supports the Unsolicited Electronic Messages Act 2007. If you do not wish to receive similar communications in future, please notify the sender of this message.
This message has been scanned for malware by SurfControl plc. www.surfcontrol.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090528/f75d6f56/attachment.html
