[OpenLayers-Users] Cluster Strategy Based on Attribute
Jerome Freyre
jerome.freyre at hispeed.ch
Thu May 28 01:57:39 EDT 2009
I think you have two solutions.
The first one is to separate your single layer in three differents layers.
The first one will contain points "Company", the second will contain points
"Airport" and the third will contain lines. Then you can easily (de)activate
a cluster strategy for the "Company layer."
Another idea is to create a new class that extend the original. In this
class, you can add the concept of cluster only if points contain an
attribute/value.
Hope it will be useful,
Jérome
Matt Kenny wrote:
> Hello,
> I've got a quick question that I'm hoping someone knows the answer to.
> I've got a single vector layer containing both point and line features.
> All features have a 'TYPE' attribute. Points are either 'TYPE:COMPANY' or
> 'TYPE:AIRPORT', and lines are always 'TYPE:ROUTE'.
> I'm wondering if it is possible to create a cluster strategy that only
> clusters features in my vector layer that are of an attribute,
> 'TYPE:COMPANY'?
> Thanks,
> Matt
> m a t t h e w k e n n y
> http://www.mkgeomatics.com
> Sent from Tempe, AZ, United States
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Cluster-Strategy-Based-on-Attribute-tp2984333p2985695.html
