[OpenLayers-Users] remove PanZoomBar
Rahn Hanno (rahn) rahn at zhaw.ch
Thu May 28 08:32:33 EDT 2009
Hello List,
Perhaps somebody can give me a tip. I have a problem with the ZoomBar and the PanBar in OpenLayers. If I add a map in my div object there are always the ZoomBar and the pan Buttons in the left upper side of the map as default. I will have this buttons outside the map. I try to delete this controls in this way:
map.removeControl(...);
But it doesn't work. I don't know the name of the control. Perhaps somebody can help me to realise this problem. I will have this functionality outside the map.
A lot of thanks for your help.
Greetings
Hanno
Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
Fachstelle Geoinformatik
Grüental, Postfach CH-8820 Wädenswil
Tel +41 (0)58 934 5592
Fax +41 (0)58 934 5580
hanno.rahn at zhaw.ch
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20090528/8a8b949d/attachment.html
