[OpenLayers-Users] remove PanZoomBar
Christopher Schmidt
crschmidt at metacarta.com
Thu May 28 09:45:06 EDT 2009
On Thu, May 28, 2009 at 02:32:33PM +0200, Rahn Hanno (rahn) wrote:
> Hello List,
> Perhaps somebody can give me a tip. I have a problem with the ZoomBar and the PanBar in OpenLayers. If I add a map in my div object there are always the ZoomBar and the pan Buttons in the left upper side of the map as default. I will have this buttons outside the map. I try to delete this controls in this way:
> map.removeControl(...);
> But it doesn't work. I don't know the name of the control. Perhaps somebody can help me to realise this problem. I will have this functionality outside the map.
> A lot of thanks for your help.
1. Removing controls doesn't take 'names', you pass the control object.
The control can be found in map.controls.
2. http://trac.openlayers.org/wiki/DefaultControls
> Greetings
> Hanno
> Hanno Rahn, Dipl.-Ing. (FH) Geoinformatik
> ZHAW Zürcher Hochschule für Angewandte Wissenschaften Umwelt und Natürliche Ressourcen
> Fachstelle Geoinformatik
> Grüental, Postfach CH-8820 Wädenswil
> Tel +41 (0)58 934 5592
> Fax +41 (0)58 934 5580
> hanno.rahn at zhaw.ch
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Christopher Schmidt
MetaCarta
