[OpenLayers-Users] Tween Example
Fubarred
joost at shaw.ca
Tue Nov 3 11:54:36 EST 2009
Thanks Eric,
I don't think that Tween is going to provide me with what I need. Perhaps
you can guide me in the right direction. Basically, I was the same smooth
transition that comes with panTo for zoomToExtent. Is there an easy way to
do this?
Also, is there a way to fade tiles in as opposed just having them pop up
unexpectedly?
Thank you in advance!
Eric Lemoine-2-2 wrote:
> On Monday, November 2, 2009, jvanulden <joost at shaw.ca> wrote:
>> Does someone have an example of how to use tween??? Thank you in advance!
> there's a manual test in the OpenLayers code base that you may find
> useful: tests/manual/tween.html
> Cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
View this message in context: http://n2.nabble.com/Tween-Example-tp3934163p3939717.html
