[OpenLayers-Users] Tween Example
Eric Lemoine
eric.lemoine at camptocamp.com
Tue Nov 3 12:49:36 EST 2009
On Tuesday, November 3, 2009, Fubarred <joost at shaw.ca> wrote:
> Thanks Eric,
> I don't think that Tween is going to provide me with what I need. Perhaps
> you can guide me in the right direction. Basically, I was the same smooth
> transition that comes with panTo for zoomToExtent. Is there an easy way to
> do this?
panTo and pan just move the map without changing the zoom level.
zoomToExtent can potentially change the zoom level, and, to my
knowledge, OpenLayers provides no tween-type transition for that case.
> Also, is there a way to fade tiles in as opposed just having them pop up
> unexpectedly?
I'm not sure this is fade in but have you looked at the
transitionEffect layer option? See the transition.html example.
cheers,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
