[OpenLayers-Users] GeoServer Proxy Extension OpenLayers
Andreas Hocevar
ahocevar at opengeo.org
Mon Nov 16 07:29:17 EST 2009
On Mon, Nov 16, 2009 at 10:49 AM, stash
<steffen.schwarz85 at googlemail.com> wrote:
> Hello,
> thanks for your answer. I have installed GS version 2.0 itself (without
> tomcat or something else). I copied the OpenLayers folder (with examples...)
> into my geoserver home_directory and started the examples. but the wfs
> didn't work.
What do you mean by home_directory? $GEOSERVER_DATA_DIR/www/ would be
the place to put your html stuff, and then you would access it from
http://localhost:8080/geoserver/www/
Now if you use the GeoServer proxy extension in this context, you have
to add localhost to the Permitted Hostnames.
Hope this helps.
Regards,
Andreas.
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
