[OpenLayers-Users] Help with OpenLayer + Google Maps
Pedro Baracho
pedropbaracho at gmail.com
Mon Nov 16 09:30:27 EST 2009
I mispelled projection parameter.
it is lowerCase:
{projection: new OpenLayers.Projection("EPSG:4326")}
On Mon, Nov 16, 2009 at 12:28 PM, Pedro Baracho <pedropbaracho at gmail.com>wrote:
> var gmap = new OpenLayers.Layer.Google(
> "Google Streets", // the default
> {"sphericalMercator": true ,numZoomLevels: 20}
> var vector_layer = new OpenLayers.Layer.Vector("title", {Projection: new
> OpenLayers.Projection("EPSG:4326")});
> On Mon, Nov 16, 2009 at 1:20 PM, hekuran S. Doli <
> hekuran.doli at logisticsplus-ks.com> wrote:
>> I'm using google map as layer in openlayer. I'm trying to add an point in
>> the map as in example http://www.logisticsplus-ks.com/testmap/. I'm
>> successfully adding the point in the map but when I move the map the point
>> changes the position. So it does not stay at the coordinates that I give it.
>> By the way the functions works perfectly with openstreet map, but not with
>> google maps.
>> In the following is the code that I'm using:
>> <script type="text/javascript">
>> var map;
>> function init() {
>> map = new OpenLayers.Map('map');
>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>> {numZoomLevels: 20}
>> map.addLayers([gmap]);
>> map.setCenter(new OpenLayers.LonLat(21.159739, 42.656138),
>> 10);
>> var featurecollection = {"type":"Feature",
>> "id":"OpenLayers.Feature.Vector_173", "properties":{},
>> "geometry":{"type":"Point", "coordinates":[21.159739, 42.656138]}};
>> function addGeoJson() {
>> var geojson_format = new OpenLayers.Format.GeoJSON();
>> var vector_layer = new OpenLayers.Layer.Vector();
>> map.addLayer(vector_layer);
>> //vector_layer.addFeatures(geojson_format.read(featurecollection));
>> </script>
>> Any help would be appreciable.
>> Thanks in advance,
>> Hekuran
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/ff9bbcc7/attachment.html
