[OpenLayers-Users] Help with OpenLayer + Google Maps
hekuran S. Doli hekuran.doli at logisticsplus-ks.com
Mon Nov 16 10:45:17 EST 2009
Dear Pedro,
Thanks a lot for your prompt reply.
I implemented your suggestion but now the map does not move and the same coordinates point elsewhere. I published the updated example at http://www.logisticsplus-ks.com/testmap/
Regards,
Hekuran
----- Original Message -----
To: "hekuran S. Doli" <hekuran.doli at logisticsplus-ks.com>
Cc: users at openlayers.org
Sent: Monday, November 16, 2009 3:30:27 PM GMT +01:00 Amsterdam / Berlin / Bern / Rome / Stockholm / Vienna
Subject: Re: [OpenLayers-Users] Help with OpenLayer + Google Maps
I mispelled projection parameter.
it is lowerCase:
{projection: new OpenLayers.Projection("EPSG:4326")}
On Mon, Nov 16, 2009 at 12:28 PM, Pedro Baracho < pedropbaracho at gmail.com > wrote:
var gmap = new OpenLayers.Layer.Google(
"Google Streets", // the default
{"sphericalMercator": true ,numZoomLevels: 20}
var vector_layer = new OpenLayers.Layer.Vector("title", {Projection: new OpenLayers.Projection("EPSG:4326")});
On Mon, Nov 16, 2009 at 1:20 PM, hekuran S. Doli < hekuran.doli at logisticsplus-ks.com > wrote:
I'm using google map as layer in openlayer. I'm trying to add an point in the map as in example http://www.logisticsplus-ks.com/testmap/ . I'm successfully adding the point in the map but when I move the map the point changes the position. So it does not stay at the coordinates that I give it.
By the way the functions works perfectly with openstreet map, but not with google maps.
In the following is the code that I'm using:
<script type="text/javascript">
var map;
function init() {
map = new OpenLayers.Map('map');
map.addControl(new OpenLayers.Control.LayerSwitcher());
{numZoomLevels: 20}
map.addLayers([gmap]);
map.setCenter(new OpenLayers.LonLat(21.159739, 42.656138), 10);
var featurecollection = {"type":"Feature", "id":"OpenLayers.Feature.Vector_173", "properties":{}, "geometry":{"type":"Point", "coordinates":[21.159739, 42.656138]}};
function addGeoJson() {
var geojson_format = new OpenLayers.Format.GeoJSON();
var vector_layer = new OpenLayers.Layer.Vector();
map.addLayer(vector_layer);
//vector_layer.addFeatures(geojson_format.read(featurecollection));
</script>
Any help would be appreciable.
Thanks in advance,
Hekuran
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/7e0ab4f0/attachment.html
