[OpenLayers-Users] Help with OpenLayer + Google Maps
Pedro Baracho pedropbaracho at gmail.com
Mon Nov 16 10:51:39 EST 2009
var center = new OpenLayers.LonLat(21.159739, 42.656138);
map.setCenter(center.transform(new OpenLayers.Projection("EPSG:4326"), new
OpenLayers.Projection("EPSG:900913")), 10)
On Mon, Nov 16, 2009 at 1:45 PM, hekuran S. Doli <
hekuran.doli at logisticsplus-ks.com> wrote:
> Dear Pedro,
> Thanks a lot for your prompt reply.
> I implemented your suggestion but now the map does not move and the same
> coordinates point elsewhere. I published the updated example at
> http://www.logisticsplus-ks.com/testmap/
> Regards,
> Hekuran
> ----- Original Message -----
> From: "Pedro Baracho" <pedropbaracho at gmail.com>
> To: "hekuran S. Doli" <hekuran.doli at logisticsplus-ks.com>
> Cc: users at openlayers.org
> Sent: Monday, November 16, 2009 3:30:27 PM GMT +01:00 Amsterdam / Berlin /
> Bern / Rome / Stockholm / Vienna
> Subject: Re: [OpenLayers-Users] Help with OpenLayer + Google Maps
> I mispelled projection parameter.
> it is lowerCase:
> {projection: new OpenLayers.Projection("EPSG:4326")}
> On Mon, Nov 16, 2009 at 12:28 PM, Pedro Baracho <pedropbaracho at gmail.com>wrote:
>> var gmap = new OpenLayers.Layer.Google(
>>                 "Google Streets", // the default
>>                 {"sphericalMercator": true ,numZoomLevels: 20}
>> var vector_layer = new OpenLayers.Layer.Vector("title", {Projection: new
>> OpenLayers.Projection("EPSG:4326")});
>> On Mon, Nov 16, 2009 at 1:20 PM, hekuran S. Doli <
>>> I'm using google map as layer in openlayer. I'm trying to add an point in
>>> the map as in example http://www.logisticsplus-ks.com/testmap/. I'm
>>> successfully adding the point in the map but when I move the map the point
>>> changes the position. So it does not stay at the coordinates that I give it.
>>> By the way the functions works perfectly with openstreet map, but not
>>> with google maps.
>>> In the following is the code that I'm using:
>>> <script type="text/javascript">
>>>         var map;
>>>         function init() {
>>>             map = new OpenLayers.Map('map');
>>>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>>>                 {numZoomLevels: 20}
>>>             map.addLayers([gmap]);
>>>             map.setCenter(new OpenLayers.LonLat(21.159739, 42.656138),
>>> 10);
>>> var featurecollection = {"type":"Feature",
>>> "id":"OpenLayers.Feature.Vector_173", "properties":{},
>>> "geometry":{"type":"Point", "coordinates":[21.159739, 42.656138]}};
>>>       function addGeoJson() {
>>>                 var geojson_format = new OpenLayers.Format.GeoJSON();
>>>                 var vector_layer = new OpenLayers.Layer.Vector();
>>>                 map.addLayer(vector_layer);
>>> //vector_layer.addFeatures(geojson_format.read(featurecollection));
>>>     </script>
>>> Any help would be appreciable.
>>> Thanks in advance,
>>> Hekuran
>>> Users mailing list
>>> Users at openlayers.org
>>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/cf0d6ed4/attachment.html
