[OpenLayers-Users] Help with OpenLayer + Google Maps
Pedro Baracho pedropbaracho at gmail.com
Mon Nov 16 11:14:12 EST 2009
I would also add these options to the map if I were you.
var options = {
                maxExtent: new
OpenLayers.Bounds(-20037508.34,-20037508.34,20037508.34,20037508.34),
                numZoomLevels:18,
                maxResolution:156543.0339,
                units:'m',
                projection: "EPSG:900913",
                displayProjection: new OpenLayers.Projection("EPSG:4326")
var map = new OpenLayers.Map("map", options);
On Mon, Nov 16, 2009 at 1:51 PM, Pedro Baracho <pedropbaracho at gmail.com>wrote:
> var center = new OpenLayers.LonLat(21.159739, 42.656138);
> map.setCenter(center.transform(new OpenLayers.Projection("EPSG:4326"), new
> OpenLayers.Projection("EPSG:900913")), 10)
> On Mon, Nov 16, 2009 at 1:45 PM, hekuran S. Doli <
> hekuran.doli at logisticsplus-ks.com> wrote:
>> Dear Pedro,
>> Thanks a lot for your prompt reply.
>> I implemented your suggestion but now the map does not move and the same
>> coordinates point elsewhere. I published the updated example at
>> http://www.logisticsplus-ks.com/testmap/
>> Regards,
>> Hekuran
>> ----- Original Message -----
>> From: "Pedro Baracho" <pedropbaracho at gmail.com>
>> To: "hekuran S. Doli" <hekuran.doli at logisticsplus-ks.com>
>> Cc: users at openlayers.org
>> Sent: Monday, November 16, 2009 3:30:27 PM GMT +01:00 Amsterdam / Berlin /
>> Bern / Rome / Stockholm / Vienna
>> Subject: Re: [OpenLayers-Users] Help with OpenLayer + Google Maps
>> I mispelled projection parameter.
>> it is lowerCase:
>> {projection: new OpenLayers.Projection("EPSG:4326")}
>> On Mon, Nov 16, 2009 at 12:28 PM, Pedro Baracho <pedropbaracho at gmail.com>wrote:
>>> var gmap = new OpenLayers.Layer.Google(
>>>                 "Google Streets", // the default
>>>                 {"sphericalMercator": true ,numZoomLevels: 20}
>>> var vector_layer = new OpenLayers.Layer.Vector("title", {Projection: new
>>> OpenLayers.Projection("EPSG:4326")});
>>> On Mon, Nov 16, 2009 at 1:20 PM, hekuran S. Doli <
>>>> I'm using google map as layer in openlayer. I'm trying to add an point
>>>> in the map as in example http://www.logisticsplus-ks.com/testmap/. I'm
>>>> successfully adding the point in the map but when I move the map the point
>>>> changes the position. So it does not stay at the coordinates that I give it.
>>>> By the way the functions works perfectly with openstreet map, but not
>>>> with google maps.
>>>> In the following is the code that I'm using:
>>>> <script type="text/javascript">
>>>>         var map;
>>>>         function init() {
>>>>             map = new OpenLayers.Map('map');
>>>>             map.addControl(new OpenLayers.Control.LayerSwitcher());
>>>>                 {numZoomLevels: 20}
>>>>             map.addLayers([gmap]);
>>>>             map.setCenter(new OpenLayers.LonLat(21.159739, 42.656138),
>>>> 10);
>>>> var featurecollection = {"type":"Feature",
>>>> "id":"OpenLayers.Feature.Vector_173", "properties":{},
>>>> "geometry":{"type":"Point", "coordinates":[21.159739, 42.656138]}};
>>>>       function addGeoJson() {
>>>>                 var geojson_format = new OpenLayers.Format.GeoJSON();
>>>>                 var vector_layer = new OpenLayers.Layer.Vector();
>>>>                 map.addLayer(vector_layer);
>>>> //vector_layer.addFeatures(geojson_format.read(featurecollection));
>>>>     </script>
>>>> Any help would be appreciable.
>>>> Thanks in advance,
>>>> Hekuran
>>>> _______________________________________________
>>>> Users mailing list
>>>> Users at openlayers.org
>>>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/30c51bc8/attachment.html
