[OpenLayers-Users] GeoServer Proxy Extension OpenLayers
Andreas Hocevar ahocevar at opengeo.org
Mon Nov 16 12:02:11 EST 2009
stash wrote:
> Andreas Hocevar-2 wrote:
>>> No, this is because you have a missing (or incorrect)
>>> OpenLayers.ProxyHost setting in your example.
>>> In a script tag after you include OpenLayers.js in your example html
>>> page, add:
>>> OpenLayers.ProxyHost="/geoserver/rest/proxy";
>> The above should read
>> OpenLayers.ProxyHost="/geoserver/rest/proxy?url=";
>> Regards,
>> Andreas.
> Hello,
> thanks for your very fast answer. I replaced the line for the proxyhost with
> 'OpenLayers.ProxyHost="/geoserver/rest/proxy?url=";'
> --> Unfortunately I get the same error.
> It's really frustrating.
> Do you have any other idea.
Only if you provide more context:
* the code of the example you are trying to run
* the url you are accessing it through
Regards,
Andreas.
> Regards
> stash
Andreas Hocevar
OpenGeo - http://opengeo.org/
Expert service straight from the developers.
