[OpenLayers-Users] GeoServer Proxy Extension OpenLayers
stash
steffen.schwarz85 at googlemail.com
Mon Nov 16 14:20:02 EST 2009
Andreas Hocevar-2 wrote:
> Only if you provide more context:
> * the code of the example you are trying to run
> * the url you are accessing it through
Hello,
yes I think this is the best idea to solve my problem. I use the following
code. It's a wms (my base layer) with a background card and a wfs with some
points located somewhere in denmark.
<html xmlns="http://www.w3.org/1999/xhtml">
<head>
<link rel="stylesheet" href="OpenLayers-2.8/theme/default/style.css"
type="text/css" />
<link rel="stylesheet" href="style.css" type="text/css" />
<script src="OpenLayers-2.8/lib/OpenLayers.js"></script>
<script type="text/javascript">
var map, layer;
function init(){
OpenLayers.ProxyHost="/geoserver/rest/proxy?url=";
var max_Extent = new OpenLayers.Bounds(
-198, -98.68117980957031,
198, 92.30477600097656
var bounds = new OpenLayers.Bounds(
1, 45,
16, 60
var options = {
controls: [],
maxExtent: max_Extent,
maxResolution: 0.5,
projection: "EPSG:4326",
units: 'degrees'
map = new OpenLayers.Map('map', options);
layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
"http://localhost:8080/geoserver/wms", {layers: 'topp:country'}
map.addLayer(layer);
layer = new OpenLayers.Layer.WFS( "Owl Survey",
"http://localhost:8080/geoserver/wfs",
{typename: "topp:MY_GAZETTEER", maxfeatures: 10},
{ featureClass: OpenLayers.Feature.WFS});
map.addControl(new OpenLayers.Control.LayerSwitcher());
map.zoomToExtent(bounds);
</script>
</head>
<body onload="init()">
<h1 id="title">WFS Points</h1>
<p id='shortdesc'>
Using a Layer.WFS with a featureClass, one can take in XML data
from a WFS class and display it any way you like.
</p>
<div id="map" class="smallmap"></div>
</body>
</html>
The wms is working, the wfs not. My browser (Internet explorer) tells me an
error at the xmlhttprequest (Access denied).
Thanks for your help.
Best regards
stash
View this message in context: http://n2.nabble.com/GeoServer-Proxy-Extension-OpenLayers-tp3998936p4014088.html
