[OpenLayers-Users] GeoServer Proxy Extension OpenLayers
Pedro Baracho
pedropbaracho at gmail.com
Mon Nov 16 14:39:23 EST 2009
What is the link on your browser when you open the example?
is it http:// ... or file:// ?
That message from IE is exactly the Cross Domain AJAX Request thing. You can
set the Security config of IE to None also. I think that will solve the
problem for IE.
Cheers
On Mon, Nov 16, 2009 at 5:20 PM, stash <steffen.schwarz85 at googlemail.com>wrote:
> Andreas Hocevar-2 wrote:
> > Only if you provide more context:
> > * the code of the example you are trying to run
> > * the url you are accessing it through
> Hello,
> yes I think this is the best idea to solve my problem. I use the following
> code. It's a wms (my base layer) with a background card and a wfs with some
> points located somewhere in denmark.
> <html xmlns="http://www.w3.org/1999/xhtml">
> <head>
> <link rel="stylesheet" href="OpenLayers-2.8/theme/default/style.css"
> type="text/css" />
> <link rel="stylesheet" href="style.css" type="text/css" />
> <script src="OpenLayers-2.8/lib/OpenLayers.js"></script>
> <script type="text/javascript">
> var map, layer;
> function init(){
> OpenLayers.ProxyHost="/geoserver/rest/proxy?url=";
> var max_Extent = new OpenLayers.Bounds(
> -198, -98.68117980957031,
> 198, 92.30477600097656
> var bounds = new OpenLayers.Bounds(
> 1, 45,
> 16, 60
> var options = {
> controls: [],
> maxExtent: max_Extent,
> maxResolution: 0.5,
> projection: "EPSG:4326",
> units: 'degrees'
> map = new OpenLayers.Map('map', options);
> layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
> "http://localhost:8080/geoserver/wms", {layers: 'topp:country'}
> map.addLayer(layer);
> layer = new OpenLayers.Layer.WFS( "Owl Survey",
> "http://localhost:8080/geoserver/wfs",
> {typename: "topp:MY_GAZETTEER", maxfeatures: 10},
> { featureClass: OpenLayers.Feature.WFS});
> map.addControl(new OpenLayers.Control.LayerSwitcher());
> map.zoomToExtent(bounds);
> </script>
> </head>
> <body onload="init()">
> <h1 id="title">WFS Points</h1>
> <p id='shortdesc'>
> Using a Layer.WFS with a featureClass, one can take in XML data
> from a WFS class and display it any way you like.
> </p>
> <div id="map" class="smallmap"></div>
> </body>
> </html>
> The wms is working, the wfs not. My browser (Internet explorer) tells me an
> error at the xmlhttprequest (Access denied).
> Thanks for your help.
> Best regards
> stash
> http://n2.nabble.com/GeoServer-Proxy-Extension-OpenLayers-tp3998936p4014088.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/7213dd4e/attachment.html
