[OpenLayers-Users] GeoServer Proxy Extension OpenLayers
Pedro Baracho
pedropbaracho at gmail.com
Mon Nov 16 14:48:19 EST 2009
In fact, changing the security settings won't solve the problem if you are
accessing it via file://
On Mon, Nov 16, 2009 at 5:39 PM, Pedro Baracho <pedropbaracho at gmail.com>wrote:
> What is the link on your browser when you open the example?
> is it http:// ... or file:// ?
> That message from IE is exactly the Cross Domain AJAX Request thing. You
> can set the Security config of IE to None also. I think that will solve the
> problem for IE.
> Cheers
> On Mon, Nov 16, 2009 at 5:20 PM, stash <steffen.schwarz85 at googlemail.com>wrote:
>> Andreas Hocevar-2 wrote:
>> > Only if you provide more context:
>> > * the code of the example you are trying to run
>> > * the url you are accessing it through
>> Hello,
>> yes I think this is the best idea to solve my problem. I use the following
>> code. It's a wms (my base layer) with a background card and a wfs with
>> some
>> points located somewhere in denmark.
>> <html xmlns="http://www.w3.org/1999/xhtml">
>> <head>
>> <link rel="stylesheet" href="OpenLayers-2.8/theme/default/style.css"
>> type="text/css" />
>> <link rel="stylesheet" href="style.css" type="text/css" />
>> <script src="OpenLayers-2.8/lib/OpenLayers.js"></script>
>> <script type="text/javascript">
>> var map, layer;
>> function init(){
>> OpenLayers.ProxyHost="/geoserver/rest/proxy?url=";
>> var max_Extent = new OpenLayers.Bounds(
>> -198, -98.68117980957031,
>> 198, 92.30477600097656
>> var bounds = new OpenLayers.Bounds(
>> 1, 45,
>> 16, 60
>> var options = {
>> controls: [],
>> maxExtent: max_Extent,
>> maxResolution: 0.5,
>> projection: "EPSG:4326",
>> units: 'degrees'
>> map = new OpenLayers.Map('map', options);
>> layer = new OpenLayers.Layer.WMS( "OpenLayers WMS",
>> "http://localhost:8080/geoserver/wms", {layers:
>> 'topp:country'}
>> map.addLayer(layer);
>> layer = new OpenLayers.Layer.WFS( "Owl Survey",
>> "http://localhost:8080/geoserver/wfs",
>> {typename: "topp:MY_GAZETTEER", maxfeatures: 10},
>> { featureClass: OpenLayers.Feature.WFS});
>> map.addControl(new OpenLayers.Control.LayerSwitcher());
>> map.zoomToExtent(bounds);
>> </script>
>> </head>
>> <body onload="init()">
>> <h1 id="title">WFS Points</h1>
>> <p id='shortdesc'>
>> Using a Layer.WFS with a featureClass, one can take in XML data
>> from a WFS class and display it any way you like.
>> </p>
>> <div id="map" class="smallmap"></div>
>> </body>
>> </html>
>> The wms is working, the wfs not. My browser (Internet explorer) tells me
>> an
>> error at the xmlhttprequest (Access denied).
>> Thanks for your help.
>> Best regards
>> stash
>> View this message in context:
>> http://n2.nabble.com/GeoServer-Proxy-Extension-OpenLayers-tp3998936p4014088.html
>> Sent from the OpenLayers Users mailing list archive at Nabble.com.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091116/9021e317/attachment.html
