[OpenLayers-Users] Query problem
Arnd Wippermann
arnd.wippermann at web.de
Tue Nov 17 13:29:06 EST 2009
"I got your second approach idea. But is that using WMSfeaturegetinfo or my
method? And it sounds like giving all queryable layers' information within
one window only, right?"
It use your method and it will only open one window. But if there is no
result for all queried layers, the window open nevertheless. If you want to
control the response from your request, you have to use an ajax call. Then
you get back the response as text and if it's not empty, you show the
response in a window.
Arnd
-----Ursprüngliche Nachricht-----
Von: users-bounces at openlayers.org [mailto:users-bounces at openlayers.org] Im
Auftrag von Aypes2
Gesendet: Dienstag, 17. November 2009 03:00
An: users at openlayers.org
Betreff: Re: [OpenLayers-Users] Query problem
Arnd Wippermann wrote:
> Hi,
> It seems, that your loop creates the window for your first queryable
> layer and then the queryresult of your next queryable layers use the
> same window and overwrite the contents of the window "getfeatureinfo". The
last wins.
> If you change the window name to "getfeatureinfo" + i, then you should
> get one window for every query.
> A second approach is to collect the visibible layers and do only one
> getfeatureinfo request with this layerlist. Then you get back from
> MapServer one result html for all the queried layers.
> Arnd
> [mailto:users-bounces at openlayers.org] Im Auftrag von Aypes2
> Gesendet: Freitag, 13. November 2009 08:24
> Betreff: [OpenLayers-Users] Query problem
Sorry for late reply. I have done what you said with "getfeatureinfo" + i,
when I click each time, there are one window for each query.
But how can I open 1 window only when querying? I have 6 layers, and if I
turn on 6 layers, 6 windows come out when clicking on the map. Only 1
windows contains information but others are useless ("EMPTY" template in
MapServer). I want the required window comes out only and the "EMPTY"
template comes out when clicked coordinates have nothing.
I think I should write some more 'if' statements to make it work, but I have
no idea about how to do this. I tried to compare the layer's
coordinates/pixels with e.xy.x and e.xy.y, so window comes out only when
they are same. But it fails, maybe I get the layer's coordinates wrongly. I
also tried to make mslayers[i] in ("&QUERY_LAYERS=" + mslayers[i]) in which
window comes out when mslayers[i] is not empty template, but fails too.
Thanks
Aypes2
View this message in context:
http://n2.nabble.com/Query-problem-tp3997793p4016028.html
Users mailing list
Users at openlayers.org
http://openlayers.org/mailman/listinfo/users
