[OpenLayers-Users] OpenLayer + Google Maps API key
Christopher Schmidt
crschmidt at metacarta.com
Thu Nov 19 08:49:51 EST 2009
On Thu, Nov 19, 2009 at 10:57:46AM +0100, Czarek Tomaszewski wrote:
> Hi,
> I’ve created application based on GWT-OpenLayer. It works OK. Application enables client to change that key in configuration form but I’ve noticed that when I put incorrect key, popup window informs me:
> “This web site needs a different Google Maps API key …” and it is OK,
> but after all, map is opening. I think it should not. I checked this also using simple example from http://workshops.opengeo.org/stack-intro/openlayers.html and problem is the same.
> Does anyone know how to solve the problem?
So your complaint is "The Google Maps API pops up an error message, but
the map still works"? This is not a problem with OpenLayers, it is a problem
with the Google Maps API (and can be caused to happen without OpenLayers
involvement at all).
OpenLayers can not do anything about this behavior.
Best Regards,
Christopher Schmidt
MetaCarta
