[OpenLayers-Users] mapExtents for Layer vs mapExtents for Map
Eric Lemoine
eric.lemoine at camptocamp.com
Mon Nov 23 02:12:18 EST 2009
On Monday, November 23, 2009, Andreas Hocevar <ahocevar at opengeo.org> wrote:
> Hi,
> srweal wrote:
>> Actually, to simplify this question a bit, can someone please just explain
>> how the setting for mapExtents on a Layer, as opposed to setting mapExtents
>> on the Map differ?
> The maxExtent of the active base layer takes precedence over the
> maxExtent of the map. For overlays, maxExtent is only used to determine
> if the layer is to be displayed or not, i.e. if it would be visible in
> the current viewport.
are you sure about that Andreas? I thought only minResolution and
maxResolution were looked at to determine whether an overlay is to be
displayed. I may be wrong, and would appreciate being corrected and
pointed to the relevant code in that case. Thanks,
Eric Lemoine
Camptocamp France SAS
Savoie Technolac, BP 352
73377 Le Bourget du Lac, Cedex
Tel : 00 33 4 79 44 44 96
Mail : eric.lemoine at camptocamp.com
http://www.camptocamp.com
