[OpenLayers-Users] maxExtents for Layer vs maxExtents for Map
Andreas Hocevar
ahocevar at opengeo.org
Mon Nov 23 02:28:48 EST 2009
srweal wrote:
> Thanks Andreas and Eric for your responses. But I still have one remaining
> question.
> If I set maxExtents on a WMS overlay layer and it is smaller than the
> maxExtents of my map, will tiles be requested from the WMS (or TileCache)
> for areas that are outside the bounds specified for the WMS layer, but still
> within the viewport that is showing the larger extent of the map?
Only if you set displayOutsideMaxExtent to true.
Regards,
Andreas.
> Steve
> Andreas Hocevar-2 wrote:
>> Hi,
>> srweal wrote:
>>> Actually, to simplify this question a bit, can someone please just
>>> explain
>>> how the setting for mapExtents on a Layer, as opposed to setting
>>> mapExtents
>>> on the Map differ?
>> The maxExtent of the active base layer takes precedence over the
>> maxExtent of the map. For overlays, maxExtent is only used to determine
>> if the layer is to be displayed or not, i.e. if it would be visible in
>> the current viewport.
>>> I'm particularly interested in whether they each limit the tiles
>>> requested
>>> from the servers. My situation is that I have a large extent I want
>>> visible
>>> on the map, but have multiple different layers that each provide tiles
>>> for
>>> smaller parts of the map extent, so I want them to only request tiles
>>> from
>>> the appropriate areas.
>> In that case you would set a large maxExtent of the map (or base layer),
>> and small maxExtents for your other layers.
>> Regards,
>> Andreas.
>> Andreas Hocevar
>> OpenGeo - http://opengeo.org/
>> Expert service straight from the developers.
>> Users mailing list
>> Users at openlayers.org
>> http://openlayers.org/mailman/listinfo/users
Andreas Hocevar
