[OpenLayers-Users] wrapDateLine with WMS,
map covered by opaque film
Sige
sigenz at yahoo.co.nz
Wed Nov 25 15:14:32 EST 2009
For those who have similar problem, there is actually a work around
http://n2.nabble.com/Tiles-outside-maxExtent-being-loaded-td1829360.html#a1829361
posted earlier on this forum , which overcomes the request for tiles outside
the maxExtent by creating a subclass of OpenLayers.Layer.WMS and overriding
the getURL() method. The new method checks the latitude bounds, setting the
URL to that of a fixed blank image if out of bounds. Thank you Jon!
Sige wrote:
> I found that wrapDateLine tries to request
> http://maps.geonet.org.nz/tilecache/tilecache.py?LAYERS=nasagm&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-90,-270,0,-180&WIDTH=256&HEIGHT=256
> map tiles outside the map extent , such as:
> [-90.0, -270.0, 0.0, -180.0], which our tilecache server is unable to
> retrieve and responds with an error message:
> An error occurred: couldn't calculate tile index for layer nasagm from
> ([0.0, -270.0, 90.0, -180.0])
> File "/usr/local/tilecache/TileCache/Service.py", line 421, in
> modPythonHandler
> host )
> While the WMS server of metacarta is able to handle such
> http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-90,-270,0,-180&WIDTH=256&HEIGHT=256
> request , and responds with an empty blue tile, I guess this might be the
> reason for the problem mentioned in my previous post. What should I do on
> the tilecache server side to handle request outside the map extent?
> Sige
> Sige wrote:
>> Hi List,
>> I am trying to make my wms (tilecached) map wrapped across the date line,
>> like:
>> var map = new OpenLayers.Map( $('map'),
>> maxResolution: 0.3515625,
>> projection: 'EPSG:4326'
>> var wms = new OpenLayers.Layer.WMS(
>> "WMS/Tilecache",
>> "http://maps.geonet.org.nz/tilecache/tilecache.py?",
>> format: 'image/png',
>> projection: 'EPSG:4326',
>> units: 'degrees',
>> layers: 'nasagm',
>> isBaseLayer: true,
>> reproject: false,
>> buffer: 1
>> {wrapDateLine: true, reproject: false}
>> map.addLayer(wms);
>> map.addControl(new OpenLayers.Control.MousePosition());
>> map.zoomToMaxExtent();
>> The map wrapped well, however, when I pan and zoom the map around, part
>> of the map or the whole map becomes opaque (like covered by a white
>> film). I am not sure if this is caused by my wms (tilecache) or
>> wrapDateLine. The WMS map works fine without wrapDateLine.
>> I have also tried the WMS from metacarta.com (mapServer) which works
>> fine:
>> var wms1 = new OpenLayers.Layer.WMS( "OpenLayers
>> Basic",//MapServer
>> "http://labs.metacarta.com/wms/vmap0",
>> {layers: 'basic'},
>> {wrapDateLine: true} );
>> map.addLayers([ wms1]);
>> Thanks,
>> Sige
View this message in context: http://n2.nabble.com/wrapDateLine-with-WMS-map-covered-by-opaque-film-tp4016174p4067382.html
