[OpenLayers-Users] wrapDateLine with WMS, map covered by opaque film
Sige sigenz at yahoo.co.nz
Sun Nov 22 15:35:33 EST 2009
I found that wrapDateLine tries to request
http://maps.geonet.org.nz/tilecache/tilecache.py?LAYERS=nasagm&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-90,-270,0,-180&WIDTH=256&HEIGHT=256
map tiles outside the map extent , such as:
[-90.0, -270.0, 0.0, -180.0], which our tilecache server is unable to
retrieve and responds with an error message:
An error occurred: couldn't calculate tile index for layer nasagm from
([0.0, -270.0, 90.0, -180.0])
  File "/usr/local/tilecache/TileCache/Service.py", line 421, in
modPythonHandler
    host )
While the WMS server of metacarta is able to handle such
http://labs.metacarta.com/wms/vmap0?LAYERS=basic&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&FORMAT=image%2Fjpeg&SRS=EPSG%3A4326&BBOX=-90,-270,0,-180&WIDTH=256&HEIGHT=256
request , and responds with an empty blue tile, I guess this might be the
reason for the problem mentioned in my previous post. What should I do on
the tilecache server side to handle request outside the map extent?
Sige
Sige wrote:
> Hi List,
> I am trying to make my wms (tilecached) map wrapped across the date line,
> like:
>  var  map = new OpenLayers.Map( $('map'),
>                          maxResolution: 0.3515625,
>                          projection: 'EPSG:4326'
>            var wms = new OpenLayers.Layer.WMS(
>                   "WMS/Tilecache",
>                    "http://maps.geonet.org.nz/tilecache/tilecache.py?",
>                                         format: 'image/png',
>                                         projection: 'EPSG:4326',
>                                         units: 'degrees',
>                                         layers: 'nasagm',
>                                         isBaseLayer: true,
>                                         reproject: false,
>                                         buffer: 1
>                    {wrapDateLine: true, reproject: false}
>                   map.addLayer(wms);
>             map.addControl(new OpenLayers.Control.MousePosition());
>             map.zoomToMaxExtent();
> The map wrapped well, however, when I pan and zoom the map around, part of
> the map or the whole map becomes opaque (like covered by a white film). I
> am not sure if this is caused by my wms (tilecache) or wrapDateLine. The
> WMS map works fine without wrapDateLine.
> I have also tried the WMS from metacarta.com (mapServer) which works fine:
>        var wms1 = new OpenLayers.Layer.WMS( "OpenLayers Basic",//MapServer
>                         "http://labs.metacarta.com/wms/vmap0",
>                         {layers: 'basic'},
>                         {wrapDateLine: true} );
>                       map.addLayers([ wms1]);
> Thanks,
> Sige
View this message in context: http://n2.nabble.com/wrapDateLine-with-WMS-map-covered-by-opaque-film-tp4016174p4047649.html
