[OpenLayers-Users] Dragging and Selecting
Mehmet Sirin
m.sirin07 at googlemail.com
Thu Nov 26 14:44:47 EST 2009
somehow my combined select and drag does not work the way I want..
for the first time I click on "marker-green" it turns into "marker blue",
but after i clicked out and reselect the feature it won't turn to blue. But
then it's still draggable.. just the selectControl seems to be deactivated.
And my second question: Is it possible to use both hover and select ?
Because turning on hover turns off the normal selectFeature ability...
take a look at the code that is responsible for the above described problem:
var vectors1 = new OpenLayers.Layer.Vector("Vector Layer 1", {
styleMap: new OpenLayers.StyleMap({
"default": new
OpenLayers.Style(OpenLayers.Util.applyDefaults({
externalGraphic: "../img/marker-green.png",
graphicOpacity: 1,
rotation: -45,
pointRadius: 10
}, OpenLayers.Feature.Vector.style["default"])),
"select": new OpenLayers.Style({
externalGraphic: "../img/marker-blue.png"
map.addLayers([wmsLayer, vectors1]);
map.addControl(new OpenLayers.Control.LayerSwitcher());
selectControl = new OpenLayers.Control.SelectFeature(
[vectors1],
clickout: true, toggle: false,
multiple: false, hover: false,
toggleKey: "ctrlKey",
multipleKey: "shiftKey"
map.addControl(selectControl);
map.setCenter(new OpenLayers.LonLat(0, 0), 3);
vectors1.addFeatures(createFeatures());
var dragFeature = new
OpenLayers.Control.DragFeature(vectors1,{});
map.addControl(dragFeature);
dragFeature.activate();
selectControl.activate();
in hope someone could help me..
regards
mehmet sirin c.
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091126/9e318e9b/attachment.html
