[OpenLayers-Users] WFS post and proxy?
JuKiM rifins at gmail.com
Mon Nov 30 03:49:07 EST 2009
Well,
test.aspx is not a proxy, is a simple aspx page that loads and returns the
information generated by the URL passed in the querystring. With this, I can
do a GET petition from the script.
I was looking a proxy to work under IIS, but the only information I found
was for Apache.. And I download "IISProxy", but I can't understand how it
works.. Is for that reason that I ended using the test.aspx. But now, I'm
looking how to do the same, with the POST.
Thanks!
2009/11/28 Eric Lemoine <eric.lemoine at camptocamp.com>
> On Thursday, November 26, 2009, JuKiM <rifins at gmail.com> wrote:
> > Hi,
> > I think that I'm missplacing something with the POST method...When I load
> an WMS, I needed to put the OpenLayers.ProxyHost = "test.aspx?url="; in
> order to get the WMS data from geoserver when the GET method is done...
> > But, what about making a POST?
> > I'm trying to understant how can I send the POST to the geoserver going
> through the test.aspx proxy?
> you need your proxy to support POST (Sorry, I don't about your test.aspx
> proxy)
> cheers,
> Eric Lemoine
> Camptocamp France SAS
> Savoie Technolac, BP 352
> 73377 Le Bourget du Lac, Cedex
> Tel : 00 33 4 79 44 44 96
> Mail : eric.lemoine at camptocamp.com
> http://www.camptocamp.com
URL: http://lists.osgeo.org/pipermail/openlayers-users/attachments/20091130/de3648c9/attachment.html
