[OpenLayers-Users] WFS + Text (Text_Symbolizer)
Ivan Grcic igrcic at gmail.com
Fri Nov 27 06:21:33 EST 2009
It's pretty simple, from the example:
label : "name: ${name}, age: ${age}",
where  ${name} -> feature.attributes.name and ${age} -> feature.attributes.age
So labels are attribute values, which you get from your geoserver that
gets it from database ;)
cheers
On Fri, Nov 27, 2009 at 9:27 AM, stash <steffen.schwarz85 at googlemail.com> wrote:
> Ivan Grcic-2 wrote:
>> http://openlayers.org/dev/examples/vector-features-with-text.html
> Hi,
> thanks for the example. After studying it, I copied the code, changed it for
> my app and it worked.
> But the disadvantage in the example is, that a predefined text (in my app i
> used: "test") is used by the stylemap.
> Because I don't want to have the same text at each point I have a small
> problem.
> The text for each point is stored in my database (which is connected to a
> layer in geoserver). Now I want to use the text from the database for each
> point instead of predefining some text.
> Is this possible? Can you tell me how to implement this.
> Thanks for the help.
> Regards
> stash
> View this message in context: http://n2.nabble.com/WFS-Text-Text-Symbolizer-tp4071914p4074588.html
> Sent from the OpenLayers Users mailing list archive at Nabble.com.
> Users mailing list
> Users at openlayers.org
> http://openlayers.org/mailman/listinfo/users
Ivan Grcic
