[OpenLayers-Users] IE: OpenLayers not visible
Kenneth Skovhede, GEOGRAF A/S
ks at geograf.dk
Fri Nov 27 06:39:42 EST 2009
The most common reason something works in FF but fails in IE is a
trailing comma:
var obj = {
x: 1,
y: 2, //<--- Causes error in IE, fine in FF
Regards, Kenneth Skovhede, GEOGRAF A/S
Chau skrev:
> Hi!
> I've made a fairly simple OpenLayers page, that just displays a map,
> zoom/pan, overview map and layercontrol. It works perfectly in FF, but in IE
> the page is visually empty. Using IE8's debugging tool, I can verify, that
> my 'map' DIV has been populated. When I pan/zoom in the window, IE is
> caching new images - just like I think it should, but still nothing is
> visible. I recieve no JS errors and a validation of the HTML and CSS code
> returns succesfully from W3.
> Can you guide me to find the problem?
> Kind regards, Casper
