[OpenLayers-Users] Is there a way to disable/enable controls?
cgp carina_palanca at forcorp.com
Fri Oct 2 18:20:47 EDT 2009
We can activate/deactivate them, but I need something to disable/enable a
control depending on certain conditions.
For example, I have a few WFS layers that I would like to edit:
Cities - handles points only
Road - handles lines only
Water bodies - handles polygons only
I have the editing toolbar that allows drawing of point, line and polygon
features. I made it so that I can only edit one layer at a time. So if
"Cities" is visible, then the drawPointFeature is "enabled" (but not
active), otherwise the drawPointFeature would be "disabled". Same thing goes
with the "Road" layer and the "Water bodies" layer.
View this message in context: http://n2.nabble.com/Is-there-a-way-to-disable-enable-controls-tp3758079p3758079.html
